{"name":"FM-Funknetz.de","description":"Communicate beyond the Region","url":"https:\/\/db0dol.fm-funknetz.de","home":"https:\/\/db0dol.fm-funknetz.de","gmt_offset":2,"timezone_string":"Europe\/Berlin","page_for_posts":0,"page_on_front":1586,"show_on_front":"page","namespaces":["oembed\/1.0","akismet\/v1","contact-form-7\/v1","embedpress\/v1","leadin\/v1","simple-history\/v1","elementor-one\/v1","elementor\/v1","elementor-pro\/v1","llar\/v1","nv\/v1\/dashboard","nv\/v1\/posts","neve_pro\/v1","elementor\/v1\/documents","elementor-ai\/v1","elementor\/v1\/feedback","wpmudev_blc\/v1","wpmudev_pcs\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/db0dol.fm-funknetz.de\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"description":"Das zu verwendende oEmbed-Format.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Die maximale Breite des eingebundenen Frames in Pixel.","type":"integer","default":600,"required":false},"maxheight":{"description":"Die maximale H\u00f6he des eingebundenen Frames in Pixel.","type":"integer","required":false},"discover":{"description":"Ob eine oEmbed-Discovery-Anfrage f\u00fcr nicht autorisierte Anbieter durchgef\u00fchrt werden soll.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/oembed\/1.0\/proxy"}]}},"\/akismet\/v1":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"akismet\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/akismet\/v1"}]}},"\/akismet\/v1\/key":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Ein 12-stelliger Akismet-API-Schl\u00fcssel. Erh\u00e4ltlich unter akismet.com\/account","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/akismet\/v1\/key"}]}},"\/akismet\/v1\/settings":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"akismet_strictness":{"type":"boolean","description":"Wenn wahr, wird Akismet den schlimmsten Spam automatisch l\u00f6schen, anstatt ihn in den Spam-Ordner zu verschieben.","required":false},"akismet_show_user_comments_approved":{"type":"boolean","description":"Wenn wahr, zeige die Anzahl der genehmigten Kommentare neben jedem Kommentarautor in der Kommentarliste an.","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/akismet\/v1\/settings"}]}},"\/akismet\/v1\/stats":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"type":"string","description":"Der Zeitraum, f\u00fcr den Statistiken abgerufen werden. Optionen: 60 Tage, 6 Monate, alle","default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/akismet\/v1\/stats"}]}},"\/akismet\/v1\/stats\/(?P<interval>[\\w+])":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"description":"Der Zeitraum, f\u00fcr den Statistiken abgerufen werden. Optionen: 60 Tage, 6 Monate, alle","type":"string","required":false}}}]},"\/akismet\/v1\/alert":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"key":{"type":"string","description":"Ein 12-stelliger Akismet-API-Schl\u00fcssel. Erh\u00e4ltlich unter akismet.com\/account","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Ein 12-stelliger Akismet-API-Schl\u00fcssel. Erh\u00e4ltlich unter akismet.com\/account","required":false}}},{"methods":["DELETE"],"args":{"key":{"type":"string","description":"Ein 12-stelliger Akismet-API-Schl\u00fcssel. Erh\u00e4ltlich unter akismet.com\/account","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/akismet\/v1\/alert"}]}},"\/akismet\/v1\/webhook":{"namespace":"akismet\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/akismet\/v1\/webhook"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/embedpress\/v1":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"embedpress\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1"}]}},"\/embedpress\/v1\/oembed\/(?P<provider>[a-zA-Z0-9\\-]+)":{"namespace":"embedpress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}]},"\/embedpress\/v1\/analytics\/track":{"namespace":"embedpress\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"content_id":{"type":"string","required":true},"interaction_type":{"type":"string","enum":["impression","click","view","play","pause","complete"],"required":true},"user_id":{"type":"string","description":"Persistent user ID from cookie","required":false},"session_id":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/track"}]}},"\/embedpress\/v1\/analytics\/data":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/data"}]}},"\/embedpress\/v1\/analytics\/content":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/content"}]}},"\/embedpress\/v1\/analytics\/views":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/views"}]}},"\/embedpress\/v1\/analytics\/spline-chart":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"date_range":{"type":"integer","default":30,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/spline-chart"}]}},"\/embedpress\/v1\/analytics\/overview":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"date_range":{"type":"integer","default":30,"required":false},"start_date":{"type":"string","required":false},"end_date":{"type":"string","required":false},"content_type":{"type":"string","enum":["all","elementor","gutenberg","shortcode"],"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/overview"}]}},"\/embedpress\/v1\/analytics\/embed-details":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"limit":{"type":"integer","default":20,"required":false},"offset":{"type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/embed-details"}]}},"\/embedpress\/v1\/analytics\/milestones":{"namespace":"embedpress\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/milestones"}]}},"\/embedpress\/v1\/analytics\/features":{"namespace":"embedpress\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/features"}]}},"\/embedpress\/v1\/analytics\/geo":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/geo"}]}},"\/embedpress\/v1\/analytics\/device":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/device"}]}},"\/embedpress\/v1\/analytics\/browser":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/browser"}]}},"\/embedpress\/v1\/analytics\/browser-info":{"namespace":"embedpress\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"user_id":{"type":"string","required":false},"session_id":{"type":"string","required":true},"browser_fingerprint":{"type":"string","required":false},"screen_resolution":{"type":"string","required":false},"language":{"type":"string","required":false},"timezone":{"type":"string","required":false},"user_agent":{"type":"string","required":false},"user_ip":{"type":"string","required":false},"country":{"type":"string","required":false},"city":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/browser-info"}]}},"\/embedpress\/v1\/analytics\/milestones\/read":{"namespace":"embedpress\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"timestamp":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/milestones\/read"}]}},"\/embedpress\/v1\/analytics\/email-settings":{"namespace":"embedpress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/email-settings"}]}},"\/embedpress\/v1\/analytics\/sync-counters":{"namespace":"embedpress\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/sync-counters"}]}},"\/embedpress\/v1\/analytics\/tracking-setting":{"namespace":"embedpress\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/tracking-setting"}]}},"\/embedpress\/v1\/analytics\/cleanup-redundant-data":{"namespace":"embedpress\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"cleanup_type":{"type":"string","enum":["duplicate_interactions","redundant_browser_info","all"],"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/cleanup-redundant-data"}]}},"\/embedpress\/v1\/analytics\/performance-stats":{"namespace":"embedpress\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/embedpress\/v1\/analytics\/performance-stats"}]}},"\/leadin\/v1":{"namespace":"leadin\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"leadin\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/leadin\/v1"}]}},"\/leadin\/v1\/healthcheck":{"namespace":"leadin\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/leadin\/v1\/healthcheck"}]}},"\/leadin\/v1\/internal-tracking":{"namespace":"leadin\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/leadin\/v1\/internal-tracking"}]}},"\/leadin\/v1\/hublet":{"namespace":"leadin\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/leadin\/v1\/hublet"}]}},"\/leadin\/v1\/skip-review":{"namespace":"leadin\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/leadin\/v1\/skip-review"}]}},"\/leadin\/v1\/track-consent":{"namespace":"leadin\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/leadin\/v1\/track-consent"}]}},"\/leadin\/v1\/business-unit":{"namespace":"leadin\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/leadin\/v1\/business-unit"}]}},"\/leadin\/v1\/wp-mappings-cache-reset":{"namespace":"leadin\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/leadin\/v1\/wp-mappings-cache-reset"}]}},"\/leadin\/v1\/wp-mappings-proxy-enabled":{"namespace":"leadin\/v1","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/leadin\/v1\/wp-mappings-proxy-enabled"}]}},"\/simple-history\/v1":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"simple-history\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1"}]}},"\/simple-history\/v1\/email-report\/preview\/email":{"namespace":"simple-history\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST","GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/email-report\/preview\/email"}]}},"\/simple-history\/v1\/email-report\/preview\/html":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/email-report\/preview\/html"}]}},"\/simple-history\/v1\/events":{"namespace":"simple-history\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"type":{"description":"Typ des Ergebnisses, das zur\u00fcckgegeben werden soll.","type":"string","default":"overview","enum":["overview","occasions"],"required":false},"logRowID":{"description":"Begrenzt die Ergebnissatz auf Zeilen mit einer niedrigeren ID als diese.","type":"integer","required":false},"occasionsID":{"description":"Begrenzt den Ergebnissatz auf Zeilen mit occasionsID gleich diesem Wert.","type":"string","required":false},"occasionsCount":{"description":"Die Anzahl der zu erhaltenen Auftreten.","type":"integer","required":false},"occasionsCountMaxReturn":{"description":"Die maximale Anzahl von Auftreten, die zur\u00fcckgegeben werden.","type":"integer","required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":null,"required":false},"max_id_first_page":{"description":"Den Ergebnissatz auf Zeilen begrenzen, deren ID gleich oder niedriger als diese ist.","type":"integer","required":false},"since_id":{"description":"Den Ergebnissatz auf Zeilen begrenzen, deren ID gr\u00f6\u00dfer als diese bzw. neuer als since_id ist.","type":"integer","required":false},"since_date":{"description":"Begrenze die Ergebnismenge auf Ereignisse mit Datum > since_date ODER (Datum = since_date UND ID > since_id). Verwende dies zusammen mit since_id f\u00fcr eine genaue Erkennung neuer Ereignisse.","type":"string","format":"date-time","required":false},"date_from":{"description":"Den Ergebnissatz auf Zeilen begrenzen, deren Datum gr\u00f6\u00dfer oder gleich diesem Unix-Zeitstempel ist.","type":"string","required":false},"date_to":{"description":"Den Ergebnissatz auf Zeilen begrenzen, deren Datum kleiner oder gleich dieses Unix-Zeitstempels ist.","type":"string","required":false},"dates":{"description":"Den Ergebnissatz auf Zeilen mit einem Datum innerhalb dieses Bereichs begrenzen.","type":"array","items":{"type":"string"},"required":false},"skip_count_query":{"description":"Skip the total count query for faster results when pagination info is not needed.","type":"boolean","default":false,"required":false},"lastdays":{"description":"Den Ergebnissatz auf Zeilen mit einem Datum innerhalb dieses Bereichs begrenzen.","type":"integer","required":false},"months":{"description":"Den Ergebnissatz auf Zeilen mit einem Datum innerhalb dieses Bereichs begrenzen. Format: J-m.","type":"array","items":{"type":"string"},"required":false},"loglevels":{"description":"Den Ergebnissatz auf Zeilen mit Protokollebenen begrenzen.","type":"array","items":{"type":"string"},"required":false},"loggers":{"description":"Den Ergebnissatz auf Zeilen mit Loggern begrenzen.","type":"array","items":{"type":"string"},"required":false},"messages":{"description":"Den Ergebnissatz auf Zeilen mit Meldungen begrenzen. Format: LoggerSlug:message.","type":"array","items":{"type":"string"},"required":false},"users":{"description":"Den Ergebnissatz auf Zeilen mit Benutzer-IDs begrenzen.","type":"array","items":{"type":"integer"},"required":false},"user":{"description":"Den Ergebnissatz auf Zeilen mit einer Benutzer-ID begrenzen.","type":"integer","required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"include_sticky":{"description":"Inkludiere \u201eoben gehaltene\u201c Ereignisse in den Ergebnissen.","type":"boolean","default":false,"required":false},"only_sticky":{"description":"Nur \u201eoben gehaltene\u201c Ereignisse ausgeben.","type":"boolean","default":false,"required":false},"initiator":{"description":"Auf Ereignisse von bestimmten Initiatoren begrenzen.","type":["string","array"],"items":{"type":"string"},"required":false},"ip_address":{"description":"Limit result set to events from a specific IP address. Supports anonymized IPs with \".x\" suffix.","type":"string","required":false},"context_filters":{"description":"Kontextfilter als Schl\u00fcssel-Wert-Paare zum Filtern von Ereignissen nach Kontextdaten.","type":"object","additionalProperties":{"type":"string"},"required":false},"metadata_search":{"description":"Plain text search across all event metadata (context values). Slower than the main search but covers IP addresses, emails, and other internal data.","type":"string","required":false},"ungrouped":{"description":"Gruppiere Ereignisse ohne Gruppierung und ohne Vorkommnisse zur\u00fcck.","type":"boolean","default":false,"required":false},"surrounding_event_id":{"description":"Zeigt Ereignisse rund um diese Ereignis-ID an. Gibt Ereignisse in chronologischer Reihenfolge vor und nach dem angegebenen Ereignis zur\u00fcck, unabh\u00e4ngig von anderen Filtern. Erfordert Administratorrechte.","type":"integer","required":false},"surrounding_count":{"description":"Anzahl der Ereignisse, die vor UND nach der surrounding_event_id angezeigt werden sollen. Standardwert 5, maximal 50.","type":"integer","default":5,"minimum":1,"maximum":50,"required":false},"exclude_search":{"description":"Ereignisse ausschlie\u00dfen, die diese W\u00f6rter enthalten. Ereignisse, die dieser Suche entsprechen, werden ausgeblendet.","type":"string","required":false},"exclude_loglevels":{"description":"Ereignisse mit diesen Log Levels ausschlie\u00dfen.","type":"array","items":{"type":"string"},"required":false},"exclude_loggers":{"description":"Ereignisse von diesen Loggern ausschlie\u00dfen.","type":"array","items":{"type":"string"},"required":false},"exclude_messages":{"description":"Ereignisse mit diesen Meldungen ausschlie\u00dfen. Format: LoggerSlug:message.","type":"array","items":{"type":"string"},"required":false},"exclude_users":{"description":"Ereignisse von diesen Benutzer IDs ausschlie\u00dfen.","type":"array","items":{"type":"integer"},"required":false},"exclude_user":{"description":"Ereignisse von dieser Benutzer ID ausschlie\u00dfen.","type":"integer","required":false},"exclude_initiator":{"description":"Ereignisse von bestimmten Ausl\u00f6sern ausschlie\u00dfen.","type":["string","array"],"items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"message":{"type":"string","description":"Short message to log","required":true},"note":{"type":"string","description":"Additional note or details about the event","required":false},"level":{"type":"string","enum":["emergency","alert","critical","error","warning","notice","info","debug"],"default":"info","description":"Log level","required":false},"date":{"type":"string","format":"date-time","description":"Date and time for the event in MySQL datetime format (Y-m-d H:i:s). If not provided, current time will be used.","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/events"}]}},"\/simple-history\/v1\/events\/has-updates":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"type":{"description":"Typ des Ergebnisses, das zur\u00fcckgegeben werden soll.","type":"string","default":"overview","enum":["overview","occasions"],"required":false},"logRowID":{"description":"Begrenzt die Ergebnissatz auf Zeilen mit einer niedrigeren ID als diese.","type":"integer","required":false},"occasionsID":{"description":"Begrenzt den Ergebnissatz auf Zeilen mit occasionsID gleich diesem Wert.","type":"string","required":false},"occasionsCount":{"description":"Die Anzahl der zu erhaltenen Auftreten.","type":"integer","required":false},"occasionsCountMaxReturn":{"description":"Die maximale Anzahl von Auftreten, die zur\u00fcckgegeben werden.","type":"integer","required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":null,"required":false},"max_id_first_page":{"description":"Den Ergebnissatz auf Zeilen begrenzen, deren ID gleich oder niedriger als diese ist.","type":"integer","required":false},"since_id":{"description":"Den Ergebnissatz auf Zeilen begrenzen, deren ID gr\u00f6\u00dfer als diese bzw. neuer als since_id ist.","type":"integer","required":true},"since_date":{"description":"Begrenze die Ergebnismenge auf Ereignisse mit Datum > since_date ODER (Datum = since_date UND ID > since_id). Verwende dies zusammen mit since_id f\u00fcr eine genaue Erkennung neuer Ereignisse.","type":"string","format":"date-time","required":false},"date_from":{"description":"Den Ergebnissatz auf Zeilen begrenzen, deren Datum gr\u00f6\u00dfer oder gleich diesem Unix-Zeitstempel ist.","type":"string","required":false},"date_to":{"description":"Den Ergebnissatz auf Zeilen begrenzen, deren Datum kleiner oder gleich dieses Unix-Zeitstempels ist.","type":"string","required":false},"dates":{"description":"Den Ergebnissatz auf Zeilen mit einem Datum innerhalb dieses Bereichs begrenzen.","type":"array","items":{"type":"string"},"required":false},"skip_count_query":{"description":"Skip the total count query for faster results when pagination info is not needed.","type":"boolean","default":false,"required":false},"lastdays":{"description":"Den Ergebnissatz auf Zeilen mit einem Datum innerhalb dieses Bereichs begrenzen.","type":"integer","required":false},"months":{"description":"Den Ergebnissatz auf Zeilen mit einem Datum innerhalb dieses Bereichs begrenzen. Format: J-m.","type":"array","items":{"type":"string"},"required":false},"loglevels":{"description":"Den Ergebnissatz auf Zeilen mit Protokollebenen begrenzen.","type":"array","items":{"type":"string"},"required":false},"loggers":{"description":"Den Ergebnissatz auf Zeilen mit Loggern begrenzen.","type":"array","items":{"type":"string"},"required":false},"messages":{"description":"Den Ergebnissatz auf Zeilen mit Meldungen begrenzen. Format: LoggerSlug:message.","type":"array","items":{"type":"string"},"required":false},"users":{"description":"Den Ergebnissatz auf Zeilen mit Benutzer-IDs begrenzen.","type":"array","items":{"type":"integer"},"required":false},"user":{"description":"Den Ergebnissatz auf Zeilen mit einer Benutzer-ID begrenzen.","type":"integer","required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"include_sticky":{"description":"Inkludiere \u201eoben gehaltene\u201c Ereignisse in den Ergebnissen.","type":"boolean","default":false,"required":false},"only_sticky":{"description":"Nur \u201eoben gehaltene\u201c Ereignisse ausgeben.","type":"boolean","default":false,"required":false},"initiator":{"description":"Auf Ereignisse von bestimmten Initiatoren begrenzen.","type":["string","array"],"items":{"type":"string"},"required":false},"ip_address":{"description":"Limit result set to events from a specific IP address. Supports anonymized IPs with \".x\" suffix.","type":"string","required":false},"context_filters":{"description":"Kontextfilter als Schl\u00fcssel-Wert-Paare zum Filtern von Ereignissen nach Kontextdaten.","type":"object","additionalProperties":{"type":"string"},"required":false},"metadata_search":{"description":"Plain text search across all event metadata (context values). Slower than the main search but covers IP addresses, emails, and other internal data.","type":"string","required":false},"ungrouped":{"description":"Gruppiere Ereignisse ohne Gruppierung und ohne Vorkommnisse zur\u00fcck.","type":"boolean","default":false,"required":false},"surrounding_event_id":{"description":"Zeigt Ereignisse rund um diese Ereignis-ID an. Gibt Ereignisse in chronologischer Reihenfolge vor und nach dem angegebenen Ereignis zur\u00fcck, unabh\u00e4ngig von anderen Filtern. Erfordert Administratorrechte.","type":"integer","required":false},"surrounding_count":{"description":"Anzahl der Ereignisse, die vor UND nach der surrounding_event_id angezeigt werden sollen. Standardwert 5, maximal 50.","type":"integer","default":5,"minimum":1,"maximum":50,"required":false},"exclude_search":{"description":"Ereignisse ausschlie\u00dfen, die diese W\u00f6rter enthalten. Ereignisse, die dieser Suche entsprechen, werden ausgeblendet.","type":"string","required":false},"exclude_loglevels":{"description":"Ereignisse mit diesen Log Levels ausschlie\u00dfen.","type":"array","items":{"type":"string"},"required":false},"exclude_loggers":{"description":"Ereignisse von diesen Loggern ausschlie\u00dfen.","type":"array","items":{"type":"string"},"required":false},"exclude_messages":{"description":"Ereignisse mit diesen Meldungen ausschlie\u00dfen. Format: LoggerSlug:message.","type":"array","items":{"type":"string"},"required":false},"exclude_users":{"description":"Ereignisse von diesen Benutzer IDs ausschlie\u00dfen.","type":"array","items":{"type":"integer"},"required":false},"exclude_user":{"description":"Ereignisse von dieser Benutzer ID ausschlie\u00dfen.","type":"integer","required":false},"exclude_initiator":{"description":"Ereignisse von bestimmten Ausl\u00f6sern ausschlie\u00dfen.","type":["string","array"],"items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/events\/has-updates"}]}},"\/simple-history\/v1\/events\/(?P<id>[\\d]+)":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutiger Bezeichner f\u00fcr das Ereignis.","type":"integer","required":false}}}]},"\/simple-history\/v1\/events\/(?P<id>[\\d]+)\/stick":{"namespace":"simple-history\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutiger Bezeichner f\u00fcr das Ereignis.","type":"integer","required":false}}}]},"\/simple-history\/v1\/backfill-status":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/backfill-status"}]}},"\/simple-history\/v1\/events\/(?P<id>[\\d]+)\/unstick":{"namespace":"simple-history\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutiger Bezeichner f\u00fcr das Ereignis.","type":"integer","required":false}}}]},"\/simple-history\/v1\/search-options":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/search-options"}]}},"\/simple-history\/v1\/search-user":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/search-user"}]}},"\/simple-history\/v1\/stats\/summary":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/summary"}]}},"\/simple-history\/v1\/stats\/users":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/users"}]}},"\/simple-history\/v1\/stats\/content":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/content"}]}},"\/simple-history\/v1\/stats\/media":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/media"}]}},"\/simple-history\/v1\/stats\/plugins":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/plugins"}]}},"\/simple-history\/v1\/stats\/core":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/core"}]}},"\/simple-history\/v1\/stats\/peak-days":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/peak-days"}]}},"\/simple-history\/v1\/stats\/peak-times":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/peak-times"}]}},"\/simple-history\/v1\/stats\/activity-overview":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/activity-overview"}]}},"\/simple-history\/v1\/stats\/notes":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"date_from":{"description":"Startdatum als Unix-Zeitstempel. Wenn nicht angegeben, werden standardm\u00e4\u00dfig 30 Tage verwendet.","type":"integer","required":false},"date_to":{"description":"Enddatum als Unix-Zeitstempel. Wenn nicht angegeben, wird das Ende des heutigen Tages als Standardwert verwendet.","type":"integer","required":false},"limit":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"include_details":{"description":"Detaillierte Statistiken einbeziehen.","type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/stats\/notes"}]}},"\/simple-history\/v1\/support-info":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/support-info"}]}},"\/simple-history\/v1\/support-info\/health-check":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/simple-history\/v1\/support-info\/health-check"}]}},"\/simple-history\/v1\/users\/(?P<id>\\d+)\/card":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"WordPress user ID.","type":"integer","required":true}}}]},"\/simple-history\/v1\/initiators\/(?P<type>[a-z_]+)\/card":{"namespace":"simple-history\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Initiator type (wp, wp_cli, web_user, other).","type":"string","enum":["wp","wp_cli","web_user","other"],"required":true}}}]},"\/elementor-one\/v1":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-one\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1"}]}},"\/elementor-one\/v1\/connect\/authorize":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"clearSession":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1\/connect\/authorize"}]}},"\/elementor-one\/v1\/connect\/disconnect":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1\/connect\/disconnect"}]}},"\/elementor-one\/v1\/connect\/switch-domain":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1\/connect\/switch-domain"}]}},"\/elementor-one\/v1\/connect\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1\/connect\/deactivate"}]}},"\/elementor-one\/v1\/top-bar\/notifications":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"app_name":{"type":"string","required":true},"app_version":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1\/top-bar\/notifications"}]}},"\/elementor-one\/v1\/top-bar\/feedback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product":{"type":"string","required":true},"subject":{"type":"string","required":true},"title":{"type":"string","required":true},"description":{"type":"string","required":true},"countryCode":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1\/top-bar\/feedback"}]}},"\/elementor-one\/v1\/themes":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true},"status":{"description":"The theme activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1\/themes"}]}},"\/elementor-one\/v1\/themes\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true}}}]},"\/elementor-one\/v1\/plugins":{"namespace":"elementor-one\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"status":{"description":"Beschr\u00e4nkt die Ergebnisse auf Plugins mit dem angegebenen Status.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1\/plugins"}]}},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/upgrade":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["active"],"required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/run":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true},"force":{"type":"boolean","default":true,"description":"Force migration even if the plugin is already connected.","required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/rollback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true}}}]},"\/elementor-one\/v1\/settings":{"namespace":"elementor-one\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-one\/v1\/settings"}]}},"\/elementor\/v1":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1"}]}},"\/elementor\/v1\/site-editor":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/site-editor"}]}},"\/elementor\/v1\/site-editor\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/site-editor\/templates"}]}},"\/elementor\/v1\/site-editor\/templates\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false}}}]},"\/elementor\/v1\/site-editor\/conditions-config":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/site-editor\/conditions-config"}]}},"\/elementor\/v1\/site-editor\/templates-conditions\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":false}}}]},"\/elementor\/v1\/site-editor\/templates-conditions-conflicts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/site-editor\/templates-conditions-conflicts"}]}},"\/elementor-pro\/v1":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-pro\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-pro\/v1"}]}},"\/elementor-pro\/v1\/license\/tier-features":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-pro\/v1\/license\/tier-features"}]}},"\/elementor-pro\/v1\/license\/get-license-status":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-pro\/v1\/license\/get-license-status"}]}},"\/llar\/v1":{"namespace":"llar\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"llar\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/llar\/v1"}]}},"\/llar\/v1\/mfa\/send-code":{"namespace":"llar\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","required":true},"secret":{"type":"string","required":true},"code":{"type":"string","required":false},"ip":{"type":"string","required":false},"browser":{"type":"string","required":false},"location":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/llar\/v1\/mfa\/send-code"}]}},"\/nv\/v1\/dashboard":{"namespace":"nv\/v1\/dashboard","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"nv\/v1\/dashboard","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/nv\/v1\/dashboard"}]}},"\/nv\/v1\/dashboard\/plugin-state\/(?P<slug>[a-z0-9-]+)":{"namespace":"nv\/v1\/dashboard","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"required":false}}}]},"\/nv\/v1\/dashboard\/activate-plugin":{"namespace":"nv\/v1\/dashboard","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/nv\/v1\/dashboard\/activate-plugin"}]}},"\/nv\/v1\/dashboard\/launch-progress":{"namespace":"nv\/v1\/dashboard","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"progress":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/nv\/v1\/dashboard\/launch-progress"}]}},"\/nv\/v1\/dashboard\/activate-module":{"namespace":"nv\/v1\/dashboard","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"required":true},"value":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/nv\/v1\/dashboard\/activate-module"}]}},"\/nv\/v1\/posts":{"namespace":"nv\/v1\/posts","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"nv\/v1\/posts","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/nv\/v1\/posts"}]}},"\/nv\/v1\/posts\/page\/(?P<page_number>\\d+)(?:\/(?P<lang>[a-zA-Z0-9-_]+))?":{"namespace":"nv\/v1\/posts","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/neve_pro\/v1":{"namespace":"neve_pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"neve_pro\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/neve_pro\/v1"}]}},"\/neve_pro\/v1\/custom-layouts\/options":{"namespace":"neve_pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"query":{"type":"string","required":false},"type":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/neve_pro\/v1\/custom-layouts\/options"}]}},"\/neve_pro\/v1\/custom-layouts\/options\/(?P<type>[a-z]+)\/(?P<id>\\d+)":{"namespace":"neve_pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"number","required":false},"type":{"type":"string","required":false}}}]},"\/neve_pro\/v1\/access-restriction\/settings":{"namespace":"neve_pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/neve_pro\/v1\/access-restriction\/settings"}]}},"\/neve_pro\/v1\/toggle_license":{"namespace":"neve_pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"type":"string","required":false},"action":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/neve_pro\/v1\/toggle_license"}]}},"\/elementor\/v1\/documents":{"namespace":"elementor\/v1\/documents","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/documents","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/documents"}]}},"\/elementor\/v1\/documents\/(?P<id>\\d+)\/media\/import":{"namespace":"elementor\/v1\/documents","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true}}}]},"\/elementor\/v1\/cache":{"namespace":"elementor\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/cache"}]}},"\/elementor\/v1\/globals":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/globals"}]}},"\/elementor\/v1\/globals\/colors":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/globals\/colors"}]}},"\/elementor\/v1\/globals\/colors\/(?P<id>[\\w-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/globals\/typography":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/globals\/typography"}]}},"\/elementor\/v1\/globals\/typography\/(?P<id>[\\w-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/settings\/(?P<key>[\\w_-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/elementor\/v1\/post":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included post types","type":"array","default":null,"required":false},"excluded_types":{"description":"Post type to exclude","type":"array","default":["e-floating-buttons","e-landing-page","elementor_library","attachment","revision","nav_menu_item","custom_css","customize_changeset"],"required":false},"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"ID":"id","post_title":"label","post_type":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false},"is_public":{"description":"Whether to include only public post types","type":"boolean","default":true,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false},"tax_query":{"description":"WP_Query tax_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/post"}]}},"\/elementor\/v1\/term":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"excluded_types":{"description":"Excluded taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"term":{"description":"Terms to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"term_id":"id","name":"label","taxonomy":"groupLabel"},"required":false},"items_count":{"description":"Terms per request","type":"integer","default":100,"required":false},"hide_empty":{"description":"Whether to include only public terms","type":"boolean","default":false,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/term"}]}},"\/elementor\/v1\/user":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":["array","string"],"default":{"ID":"id","display_name":"label","role":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/user"}]}},"\/elementor-ai\/v1":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-ai\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-ai\/v1"}]}},"\/elementor-ai\/v1\/permissions":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-ai\/v1\/permissions"}]}},"\/elementor\/v1\/favorites":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/favorites"}]}},"\/elementor\/v1\/favorites\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to create.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to delete.","type":"string","required":true}}}]},"\/elementor\/v1\/kit-elements-defaults":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/kit-elements-defaults"}]}},"\/elementor\/v1\/kit-elements-defaults\/(?P<type>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","description":"The type of the element.","required":true},"settings":{"description":"All the default values for the requested type","type":"object","required":true}}},{"methods":["DELETE"],"args":{"type":{"type":"string","description":"The type of the element.","required":true}}}]},"\/elementor\/v1\/site-navigation\/recent-posts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"posts_per_page":{"description":"Number of posts to return","type":"integer","required":true},"post_type":{"description":"Post types to retrieve","type":"array","default":["page","post","elementor_library"],"required":false},"post__not_in":{"description":"Post id`s to exclude","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/site-navigation\/recent-posts"}]}},"\/elementor\/v1\/site-navigation\/add-new-post":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"Post type to create","type":"string","default":"post","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/site-navigation\/add-new-post"}]}},"\/elementor\/v1\/design-system-sync\/stylesheet":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/design-system-sync\/stylesheet"}]}},"\/elementor\/v1\/checklist":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/checklist"}]}},"\/elementor\/v1\/checklist\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/checklist\/steps"}]}},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"The step id.","required":true}}}]},"\/elementor\/v1\/checklist\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/checklist\/user-progress"}]}},"\/elementor\/v1\/operations\/opt-in-v4":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/operations\/opt-in-v4"}]}},"\/elementor\/v1\/feedback":{"namespace":"elementor\/v1\/feedback","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/feedback","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/feedback"}]}},"\/elementor\/v1\/feedback\/submit":{"namespace":"elementor\/v1\/feedback","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/feedback\/submit"}]}},"\/elementor\/v1\/template-library\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"title":{"type":"string","description":"The title of the document","required":false},"type":{"description":"The document type.","type":"string","enum":["page","section","container","landing-page","floating-buttons","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","loop-item"],"required":true},"content":{"description":"Elementor data object","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/template-library\/templates"}]}},"\/elementor\/v1\/user-data\/current-user":{"namespace":"elementor\/v1","methods":["GET","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":{"suppressedMessages":{"type":"array","description":"Array of suppressed message keys","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/user-data\/current-user"}]}},"\/elementor\/v1\/onboarding":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/onboarding"}]}},"\/elementor\/v1\/onboarding\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/onboarding\/user-progress"}]}},"\/elementor\/v1\/onboarding\/user-choices":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/onboarding\/user-choices"}]}},"\/elementor\/v1\/onboarding\/pro-install-screen":{"namespace":"elementor\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/onboarding\/pro-install-screen"}]}},"\/elementor\/v1\/onboarding\/install-pro":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/onboarding\/install-pro"}]}},"\/elementor\/v1\/onboarding\/install-theme":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/onboarding\/install-theme"}]}},"\/elementor\/v1\/global-widget\/templates":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/global-widget\/templates"}]}},"\/elementor-pro\/v1\/posts-widget":{"namespace":"elementor-pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-pro\/v1\/posts-widget"}]}},"\/elementor\/v1\/form-submissions":{"namespace":"elementor\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","additionalProperties":{"context":"filter"},"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"order_by":{"description":"Sort collection by object attribute.","type":"string","default":"created_at","enum":["created_at","id","main_meta_id"],"required":false},"status":{"description":"Limit result set to submissions assigned one or more statuses.","type":"string","default":"all","enum":["all","unread","read","trash"],"additionalProperties":{"context":"filter"},"required":false},"form":{"description":"Limit result set to submissions assigned to specific forms. The form id should follow this pattern {post_id}_{element_id} e.g: 10_476d0ce","type":"string","additionalProperties":{"context":"filter"},"required":false},"referer":{"description":"Limit result set to submissions assigned to specific referer.","type":"string","additionalProperties":{"context":"filter"},"required":false},"after":{"description":"Limit response to submissions sent after a given ISO8601 compliant date.","type":"string","format":"date","additionalProperties":{"context":"filter"},"required":false},"before":{"description":"Limit response to submissions sent before a given ISO8601 compliant date.","type":"string","format":"date","additionalProperties":{"context":"filter"},"required":false}}},{"methods":["DELETE"],"args":{"ids":{"description":"Unique identifiers for the objects.","type":"array","items":{"type":"integer"},"required":true},"force":{"description":"Delete the object permanently.","type":"boolean","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"ids":{"description":"Unique identifiers for the objects.","type":"array","items":{"type":"integer"},"required":true},"is_read":{"description":"mark whether the submission was read or not","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/form-submissions"}]}},"\/elementor\/v1\/form-submissions\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"force":{"description":"Delete the object permanently.","type":"boolean","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true},"is_read":{"description":"mark whether the submission was read or not","type":"boolean","required":false},"values":{"description":"Form field values, receive an array, the key should be the form field id and the value should be the value.","type":"object","required":false}}}]},"\/elementor\/v1\/form-submissions\/restore\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/form-submissions\/restore":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"ids":{"description":"Unique identifiers for the objects.","type":"array","items":{"type":"integer"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/form-submissions\/restore"}]}},"\/elementor\/v1\/form-submissions\/export":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Current page of the collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum number of items to be returned in result set.","type":"integer","default":10,"minimum":1,"maximum":10000,"required":false},"search":{"description":"Limit results to those matching a string.","type":"string","additionalProperties":{"context":"filter"},"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"order_by":{"description":"Sort collection by object attribute.","type":"string","default":"created_at","enum":["created_at","id","main_meta_id"],"required":false},"status":{"description":"Limit result set to submissions assigned one or more statuses.","type":"string","default":"all","enum":["all","unread","read","trash"],"additionalProperties":{"context":"filter"},"required":false},"form":{"description":"Limit result set to submissions assigned to specific forms. The form id should follow this pattern {post_id}_{element_id} e.g: 10_476d0ce","type":"string","additionalProperties":{"context":"filter"},"required":false},"referer":{"description":"Limit result set to submissions assigned to specific referer.","type":"string","additionalProperties":{"context":"filter"},"required":false},"after":{"description":"Limit response to submissions sent after a given ISO8601 compliant date.","type":"string","format":"date","additionalProperties":{"context":"filter"},"required":false},"before":{"description":"Limit response to submissions sent before a given ISO8601 compliant date.","type":"string","format":"date","additionalProperties":{"context":"filter"},"required":false},"ids":{"description":"Unique identifiers for the objects.","type":"array","items":{"type":"integer"},"additionalProperties":{"context":"filter"},"required":false},"format":{"description":"The format of the export (for now only csv).","enum":["csv"],"default":"csv","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/form-submissions\/export"}]}},"\/elementor\/v1\/form-submissions\/referer":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made, determines fields present in response. (only \"options\" available for now)","type":"string","enum":["options"],"default":"options","required":false},"search":{"description":"Limit results to those matching a string.","type":"string","additionalProperties":{"context":"filter"},"required":false},"value":{"description":"Limit results specific referer.","type":"string","additionalProperties":{"context":"filter"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/form-submissions\/referer"}]}},"\/elementor\/v1\/forms":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scope under which the request is made, determines fields present in response. (only \"options\" available for now)","type":"string","enum":["options"],"default":"options","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/forms"}]}},"\/elementor-pro\/v1\/get-post-type-taxonomies":{"namespace":"elementor-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"The post type for which to fetch the list of taxonomies.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-pro\/v1\/get-post-type-taxonomies"}]}},"\/elementor-pro\/v1\/refresh-loop":{"namespace":"elementor-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"The post ID of the page containing the loop.","type":"integer","required":true},"widget_id":{"description":"The ID of the loop widget.","type":"string","required":true},"widget_filters":{"description":"The filters for the loop widget.","type":"object","required":true},"widget_model":{"description":"The model of the loop widget. In Editor mode only.","type":"object","required":false},"pagination_base_url":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-pro\/v1\/refresh-loop"}]}},"\/elementor-pro\/v1\/refresh-search":{"namespace":"elementor-pro\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"The post ID of the page containing the loop.","type":"integer","required":true},"widget_id":{"description":"The ID of the loop widget.","type":"string","required":true},"widget_model":{"description":"The model of the loop widget. In Editor mode only.","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor-pro\/v1\/refresh-search"}]}},"\/elementor\/v1\/notes":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"route_url":{"type":"string","description":"The URL of the route where the note was created at.","required":false},"status":{"type":"string","description":"The note status (e.g. \"publish\", \"draft\").","enum":["publish","draft"],"default":"publish","required":false},"is_resolved":{"type":"boolean","description":"Whether the note is resolved or not.","required":false},"parent_id":{"type":"integer","description":"The note's parent id (use 0 for top-level).","required":false},"post_id":{"type":"integer","description":"The ID of the post that the note is attached to.","required":false},"only_unread":{"type":"boolean","description":"Show only unread notes (represents an unread thread if one of its replies is unread).","required":false},"only_relevant":{"type":"boolean","description":"Show only notes that are relevant to the current user.","required":false},"order_by":{"type":"string","description":"A column to order the results by.","default":"last_activity_at","enum":["last_activity_at","created_at"],"required":false},"order":{"type":"string","description":"Results order direction.","default":"desc","enum":["asc","desc"],"required":false}}},{"methods":["POST"],"args":{"post_id":{"type":"integer","description":"The id of the post where the note was created at (can be template, post, page, etc.).","required":true},"element_id":{"type":"string","description":"Each note must be attached to an elementor element.","required":true},"content":{"type":"string","description":"The content of the note.","required":true},"position":{"type":"object","properties":{"x":{"required":true,"type":"number"},"y":{"required":true,"type":"number"}},"description":"The position of the note.","required":true},"mentioned_usernames":{"type":"array","description":"List of user names that have been mentioned in the note's content.","default":[],"items":{"type":"string","sanitize_callback":{}},"required":false},"route_post_id":{"description":"The ID of the post that's associated with the route (doesn't always exist, e.g: home page, archive)","required":false},"route_url":{"type":"string","description":"The URL of the route where the note was created at.","required":false},"route_title":{"type":"string","description":"The title of the route where the note was created at.","required":false},"parent_id":{"type":"integer","description":"If the new note is a reply to another note, the parent_id should be the thread's id.","default":0,"required":false},"is_public":{"type":"boolean","description":"Should this note be visible for everyone or just for its author.","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/notes"}]}},"\/elementor\/v1\/notes\/read-status":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"ids":{"type":"array","description":"The id's of the notes.","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"ids":{"type":"array","description":"The id's of the notes.","items":{"type":"integer"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/notes\/read-status"}]}},"\/elementor\/v1\/notes\/summary":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"route_url":{"type":"string","description":"The URL of the route where the note was created at.","required":false},"status":{"type":"string","description":"The note status (e.g. \"publish\", \"draft\").","enum":["publish","draft"],"default":"publish","required":false},"is_resolved":{"type":"boolean","description":"Whether the note is resolved or not.","required":false},"parent_id":{"type":"integer","description":"The note's parent id (use 0 for top-level).","required":false},"post_id":{"type":"integer","description":"The ID of the post that the note is attached to.","required":false},"only_unread":{"type":"boolean","description":"Show only unread notes (represents an unread thread if one of its replies is unread).","required":false},"only_relevant":{"type":"boolean","description":"Show only notes that are relevant to the current user.","required":false},"order_by":{"type":"string","description":"A column to order the results by.","default":"last_activity_at","enum":["last_activity_at","created_at"],"required":false},"order":{"type":"string","description":"Results order direction.","default":"desc","enum":["asc","desc"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/notes\/summary"}]}},"\/elementor\/v1\/notes\/users":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"limit":{"type":"integer","description":"Limit the results.","required":false},"order_by":{"type":"string","description":"A column to order the results by.","default":"display_name","enum":["user_nicename","display_name","user_registered"],"required":false},"order":{"type":"string","description":"Results order direction.","default":"asc","enum":["asc","desc"],"required":false},"search":{"type":"string","description":"Filter users by a search term.","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/notes\/users"}]}},"\/elementor\/v1\/notes\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"Note ID to find.","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"integer","description":"The id the note.","required":true},"content":{"type":"string","description":"The content of the note.","required":false},"mentioned_usernames":{"type":"array","description":"List of user names that have been mentioned in the note's content.","items":{"type":"string","sanitize_callback":{}},"required":false},"status":{"type":"string","description":"Note status can be draft or publish.","enum":["publish","draft"],"required":false},"is_public":{"type":"boolean","description":"Should this note be visible for everyone or just for its author.","required":false},"is_resolved":{"type":"boolean","description":"Is this note resolved and should be hidden.","required":false}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"The id of the note.","required":true},"force":{"type":"boolean","description":"Determine if it should be deleted permanently or change the status to trash.","default":false,"required":false}}}]},"\/wpmudev_blc\/v1":{"namespace":"wpmudev_blc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpmudev_blc\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wpmudev_blc\/v1"}]}},"\/wpmudev_blc\/v1\/scan":{"namespace":"wpmudev_blc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wpmudev_blc\/v1\/scan"}]}},"\/wpmudev_blc\/v1\/avatars":{"namespace":"wpmudev_blc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wpmudev_blc\/v1\/avatars"}]}},"\/wpmudev_blc\/v1\/settings":{"namespace":"wpmudev_blc\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wpmudev_blc\/v1\/settings"}]}},"\/wpmudev_pcs\/v1":{"namespace":"wpmudev_pcs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpmudev_pcs\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wpmudev_pcs\/v1"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin"}]}},"\/elementor\/v1\/library\/connect":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","description":"Connect CLI token","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/library\/connect"}]}},"\/elementor\/v1\/send-event":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}},{"methods":["POST"],"args":{"event_data":{"description":"All the recorded event data in JSON format","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/elementor\/v1\/send-event"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Abfrage der Begriffs-ID-Taxonomie","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Abfrage der Begriffs-ID-Taxonomie","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Abfrage der Begriffs-ID-Taxonomie","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Abfrage der Begriffs-ID-Taxonomie","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Ergebnissatz auf Elemente begrenzen, die oben gehalten werden.","type":"boolean","required":false},"ignore_sticky":{"description":"Ob oben gehaltene Beitr\u00e4ge ignoriert werden sollen oder nicht.","type":"boolean","default":true,"required":false},"format":{"description":"Ergebnissatz auf Elemente begrenzen, denen ein oder mehrere bestimmte Formate zugeordnet sind.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einem bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Begrenzt den Ergebnissatz auf Anh\u00e4nge eines bestimmten Medientyps oder bestimmter Medientypen.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Begrenzt den Ergebnissatz auf Anh\u00e4nge eines bestimmten MIME-Typs oder bestimmter MIME-Typen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der anzeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Der Untertitel des Anhangs.","type":"object","properties":{"raw":{"description":"Der Untertitel f\u00fcr den Anhang, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Der f\u00fcr die Anzeige umgewandelte HTML-Untertitel des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, der dem Anhang zugeordnet ist.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der anzeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Der Untertitel des Anhangs.","type":"object","properties":{"raw":{"description":"Der Untertitel f\u00fcr den Anhang, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Der f\u00fcr die Anzeige umgewandelte HTML-Untertitel des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, der dem Anhang zugeordnet ist.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL zur bearbeiteten Bilddatei.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array an Bildbearbeitungen.","type":"array","minItems":1,"items":{"description":"Bildbearbeitung.","type":"object","required":["type","args"],"oneOf":[{"title":"Spiegeln","properties":{"type":{"description":"Die Art der Spiegelung.","type":"string","enum":["flip"]},"args":{"description":"Die Spiegelungs-Argumente.","type":"object","required":["flip"],"properties":{"flip":{"description":"Die Richtung der Spiegelung.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Ob in horizontaler Richtung gespiegelt werden soll.","type":"boolean"},"vertical":{"description":"Ob in vertikaler Richtung gespiegelt werden soll.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Rotations-Typ.","type":"string","enum":["rotate"]},"args":{"description":"Rotations-Argumente.","type":"object","required":["angle"],"properties":{"angle":{"description":"Winkel in Grad f\u00fcr die Rotation im Uhrzeigersinn.","type":"number"}}}}},{"title":"Zuschneiden","properties":{"type":{"description":"Typ des Zuschnitts.","type":"string","enum":["crop"]},"args":{"description":"Zuschnitt-Argumente.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horizontale Position von links, um den Zuschnitt der Bildbreite in Prozent zu beginnen.","type":"number"},"top":{"description":"Vertikale Position von oben, um den Zuschnitt der Bildh\u00f6he in Prozent zu beginnen.","type":"number"},"width":{"description":"Die Breite des Zuschnitts als ein Prozentwert der Bildbreite.","type":"number"},"height":{"description":"Die H\u00f6he des Zuschnitts als ein Prozentwert der Bildh\u00f6he.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Der Bereich in Grad, um den das Bild im Uhrzeigersinn gedreht werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Die x-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Die y-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Die Breite des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Die H\u00f6he des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Der Untertitel des Anhangs.","type":"object","properties":{"raw":{"description":"Der Untertitel f\u00fcr den Anhang, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Der f\u00fcr die Anzeige umgewandelte HTML-Untertitel des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, der dem Anhang zugeordnet ist.","type":"integer","required":false},"alt_text":{"description":"Alternativtext, der anzeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Abfrage der Begriffs-ID-Taxonomie","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Abfrage der Begriffs-ID-Taxonomie","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einem bestimmten menu_order-Wert haben.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"parent":{"default":0,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Link-Elements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Link-Element dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"default":1,"description":"Die DB-ID vom nav_menu_item des \u00fcbergeordneten Objekts dieses Men\u00fceintrags, falls es eines gibt, sonst 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"default":0,"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Link-Elements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Link-Elements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Link-Element dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID vom nav_menu_item des \u00fcbergeordneten Objekts dieses Men\u00fceintrags, falls es eines gibt, sonst 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Link-Elements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Link-Elements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Link-Element dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID vom nav_menu_item des \u00fcbergeordneten Objekts dieses Men\u00fceintrags, falls es eines gibt, sonst 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Link-Elements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Abfrage der Begriffs-ID-Taxonomie","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Abfrage der Begriffs-ID-Taxonomie","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Begrenzung des ausgew\u00e4hlten Bereichs des Template-Teils.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, um das Fallback zu erhalten f\u00fcr","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.).","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Begrenzung des ausgew\u00e4hlten Bereichs des Template-Teils.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.).","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, um das Fallback zu erhalten f\u00fcr","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.).","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision der globalen Stile.","type":"integer","required":false},"id":{"description":"Eindeutiger Identifikator der Revision f\u00fcr globale Stile.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Bezeichnung des Themes","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Bezeichnung des Themes","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Die ID der globalen Stile-Konfiguration.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Globale Stile.","type":["object"],"required":false},"settings":{"description":"Globale Einstellungen.","type":["object"],"required":false},"title":{"description":"Der Titel der globalen Stile-Variation.","type":["object","string"],"properties":{"raw":{"description":"Der Titel der globalen Stile-Variation, wie er in der Datenbank existiert.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Schriftfamilie der Schriftart.","type":"integer","required":true},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Schriftfamilie der Schriftart.","type":"integer","required":true},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"Schriftart-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Schriftfamilie der Schriftart.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr die Schriftart.","type":"integer","required":true},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Schriftfamilie der Schriftart.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr die Schriftart.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/e-floating-buttons":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einem bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","any"],"type":"string"},"required":false},"format":{"description":"Ergebnissatz auf Elemente begrenzen, denen ein oder mehrere bestimmte Formate zugeordnet sind.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/e-floating-buttons"}]}},"\/wp\/v2\/e-floating-buttons\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/elementor_library":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/elementor_library"}]}},"\/wp\/v2\/elementor_library\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/elementor_snippet":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"_elementor_location":{"type":"string","title":"","description":"","default":"elementor_head","enum":["elementor_head","elementor_body_start","elementor_body_end"]},"_elementor_priority":{"type":"integer","title":"","description":"","default":1},"_elementor_code":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/elementor_snippet"}]}},"\/wp\/v2\/elementor_snippet\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"_elementor_location":{"type":"string","title":"","description":"","default":"elementor_head","enum":["elementor_head","elementor_body_start","elementor_body_end"]},"_elementor_priority":{"type":"integer","title":"","description":"","default":1},"_elementor_code":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/neve_custom_layouts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einem bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie man Suchbegriffe interpretiert.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"custom-layout-options-layout":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-hook":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-sidebar":{"type":"string","title":"","description":"","default":"blog"},"custom-layout-options-sidebar-action":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-should-expire":{"type":"boolean","title":"","description":"","default":false},"custom-layout-expiration-date":{"type":"string","title":"","description":"","default":""},"custom-layout-options-inside-display":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-events-no":{"type":"integer","title":"","description":"","default":1},"custom-layout-options-priority-v2":{"type":"integer","title":"","description":"","default":10},"custom-layout-conditional-logic":{"type":"string","title":"","description":"","default":""},"cs-layout":{"type":"boolean","title":"","description":"","default":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/neve_custom_layouts"}]}},"\/wp\/v2\/neve_custom_layouts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"custom-layout-options-layout":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-hook":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-sidebar":{"type":"string","title":"","description":"","default":"blog"},"custom-layout-options-sidebar-action":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-should-expire":{"type":"boolean","title":"","description":"","default":false},"custom-layout-expiration-date":{"type":"string","title":"","description":"","default":""},"custom-layout-options-inside-display":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-events-no":{"type":"integer","title":"","description":"","default":1},"custom-layout-options-priority-v2":{"type":"integer","title":"","description":"","default":10},"custom-layout-conditional-logic":{"type":"string","title":"","description":"","default":""},"cs-layout":{"type":"boolean","title":"","description":"","default":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/neve_custom_layouts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/neve_custom_layouts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/neve_custom_layouts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam"],"required":false},"password":{"description":"Ein Passwort, um vor Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"content-type":{"type":"string","title":"","description":"","default":""},"neve_meta_sidebar":{"type":"string","title":"","description":"","default":""},"neve_meta_container":{"type":"string","title":"","description":"","default":""},"neve_meta_enable_content_width":{"type":"string","title":"","description":"","default":""},"neve_meta_content_width":{"type":"integer","title":"","description":"","default":0},"neve_meta_title_alignment":{"type":"string","title":"","description":"","default":""},"neve_meta_author_avatar":{"type":"string","title":"","description":"","default":""},"neve_post_elements_order":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_header":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_footer":{"type":"string","title":"","description":"","default":""},"neve_meta_disable_title":{"type":"string","title":"","description":"","default":""},"neve_meta_reading_time":{"type":"string","title":"","description":"","default":""},"custom-layout-options-layout":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-hook":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-sidebar":{"type":"string","title":"","description":"","default":"blog"},"custom-layout-options-sidebar-action":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-should-expire":{"type":"boolean","title":"","description":"","default":false},"custom-layout-expiration-date":{"type":"string","title":"","description":"","default":""},"custom-layout-options-inside-display":{"type":"string","title":"","description":"","default":"none"},"custom-layout-options-events-no":{"type":"integer","title":"","description":"","default":1},"custom-layout-options-priority-v2":{"type":"integer","title":"","description":"","default":10},"custom-layout-conditional-logic":{"type":"string","title":"","description":"","default":""},"cs-layout":{"type":"boolean","title":"","description":"","default":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","landing-page","floating-buttons","cloud-template-preview","widget","popup","header","footer","single","single-post","single-page","archive","search-results","error-404","code_snippet","loop-item",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]},"_elementor_conditions":{"type":"array","title":"","description":"Elementor conditions","default":[],"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/neve_custom_layouts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Eine alphanumerische Kennung f\u00fcr den Inhaltstyp.","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Eine alphanumerische Kennung f\u00fcr den Status.","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Ergebnisse auf Taxonomien begrenzen, die einem bestimmten Inhaltstyp zugeordnet sind.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Eine alphanumerische Kennung f\u00fcr die Taxonomie.","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Begriffs.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe verborgen werden, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Begriffs.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe verborgen werden, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Begriffs.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe verborgen werden, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der ersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der ersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortiere die Sammlung nach einem Attribut des Begriffs.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe verborgen werden, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"default":"asc","description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sammlung nach Benutzerattribut sortieren.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Ergebnissatz auf Benutzer mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Ergebnissatz auf Benutzer begrenzen, die mindestens einer bestimmten Rolle entsprechen. Akzeptiert eine CSV-Liste oder einzelne Rolle.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die mindestens eine bestimmte angegebene Berechtigung haben. Akzeptiert werden eine CSV-Liste oder eine einzelne Berechtigung.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Ergebnissatz auf Benutzer begrenzen, die als Autoren gelten.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die Beitr\u00e4ge ver\u00f6ffentlicht haben.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","e-floating-buttons":"e-floating-buttons","elementor_library":"elementor_library","elementor_snippet":"elementor_snippet","neve_custom_layouts":"neve_custom_layouts"}},"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":true},"name":{"description":"Anzeige-Name f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":true},"url":{"description":"URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":true},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Anzeige-Name f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die gel\u00f6schten Beitr\u00e4ge und Links des Benutzers dieser Benutzer-ID erneut zuweisen.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Anzeige-Name f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die gel\u00f6schten Beitr\u00e4ge und Links des Benutzers dieser Benutzer-ID erneut zuweisen.","required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Ein UUID, der von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, einen UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu benutzen.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Ein UUID, der von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, einen UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu benutzen.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Kommentare einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Kommentare begrenzen, denen bestimmte Benutzer-IDs zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Stelle sicher, dass der Ergebnissatz Kommentare ausschlie\u00dft, die einer bestimmten Benutzer-ID zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Den Ergebnissatz auf den einer speziellen E-Mail-Adresse eines Autors begrenzen. Erfordert eine Autorisierung.","format":"email","type":"string","required":false},"before":{"description":"Antwort auf Kommentare einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Kommentarattribut sortieren.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Den Ergebnissatz auf Kommentare bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Stelle sicher, dass der Ergebnissatz bestimmte \u00fcbergeordnete IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ergebnissatz auf Kommentare begrenzen, die bestimmten Beitrags-IDs zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Status zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"type":{"default":"comment","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Typ zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"Die ID des Objekts des Benutzers, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Anzeige-Name f\u00fcr den Autor des Kommentars.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"default":0,"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"author":{"description":"Die ID des Objekts des Benutzers, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Anzeige-Name f\u00fcr den Autor des Kommentars.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"type":{"default":"post","description":"Ergebnisse auf Elemente eines Objekt-Typs beschr\u00e4nken.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Ergebnisse auf ein oder mehrerer Objekt-Subtypen einschr\u00e4nken.","type":"array","items":{"enum":["post","page","e-floating-buttons","elementor_library","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Eindeutiger registrierter Name f\u00fcr den Block.","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attribute f\u00fcr den Block.","type":"object","default":[],"required":false},"post_id":{"description":"ID des Beitrag-Kontextes.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Blockname.","type":"string","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"nv_pro_blog_pro_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_hfg_module_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_performance_features_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_woocommerce_booster_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_elementor_booster_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_white_label_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_custom_layouts_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_lifterlms_booster_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_typekit_fonts_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_easy_digital_downloads_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_block_editor_booster_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_custom_sidebars_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_dashboard_customizer_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_access_restriction_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_post_type_enhancements_status":{"title":"","description":"","type":"boolean","required":false},"nv_pro_hide_sparks_customizer_notice":{"title":"","description":"","type":"boolean","required":false},"nv_pro_sparks_installation_notice":{"title":"","description":"","type":"string","required":false},"neve_pro_typekit_data":{"title":"","description":"","type":"string","required":false},"neve_logger_flag":{"title":"","description":"","type":"string","required":false},"nv_pro_enable_local_fonts":{"title":"","description":"","type":"boolean","required":false},"nv_pro_enable_featured_image_taxonomy":{"title":"","description":"","type":"boolean","required":false},"nv_pro_featured_image_taxonomies":{"title":"","description":"","type":"array","items":{"type":"string"},"required":false},"nv_pro_enable_mega_menu":{"title":"","description":"","type":"boolean","required":false},"nv_pro_enable_emoji_removal":{"title":"","description":"","type":"boolean","required":false},"nv_pro_enable_embedded_removal":{"title":"","description":"","type":"boolean","required":false},"nv_pro_enable_lazy_content":{"title":"","description":"","type":"boolean","required":false},"nv_pro_typekit_id":{"title":"","description":"","type":"string","required":false},"nv_pro_typekit_loading_method":{"title":"","description":"","type":"string","required":false},"nv_pro_neve_access_restriction":{"title":"","description":"","type":"string","required":false},"title":{"title":"Titel","description":"Website-Titel.","type":"string","required":false},"description":{"title":"Untertitel","description":"Website-Untertitel.","type":"string","required":false},"url":{"title":"","description":"Website-URL.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Diese Adresse wird f\u00fcr administrative Zwecke verwendet, wie Benachrichtigungen \u00fcber neue Benutzer.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Eine Stadt in deiner Zeitzone.","type":"string","required":false},"date_format":{"title":"","description":"Ein Datumsformat f\u00fcr alle datumsbasierten Zeichenfolgen.","type":"string","required":false},"time_format":{"title":"","description":"Ein Zeitformat f\u00fcr alle zeitbasierten Zeichenfolgen.","type":"string","required":false},"start_of_week":{"title":"","description":"Die Zahl eines Wochentages, mit dem die Woche beginnen sollte.","type":"integer","required":false},"language":{"title":"","description":"WordPress-L\u00e4ndercode.","type":"string","required":false},"use_smilies":{"title":"","description":"Emoticons wie :-) und :-P als Grafiken anzeigen.","type":"boolean","required":false},"default_category":{"title":"","description":"Standard-Beitragskategorie.","type":"integer","required":false},"default_post_format":{"title":"","description":"Standard-Beitragsformat.","type":"string","required":false},"posts_per_page":{"title":"Maximale Beitragsanzahl pro Seite","description":"Maximal angezeigte Beitr\u00e4ge.","type":"integer","required":false},"show_on_front":{"title":"Vorne anzeigen","description":"Was auf der Homepage angezeigt werden soll","type":"string","required":false},"page_on_front":{"title":"Titelseite","description":"Die ID der Seite, die auf der Startseite angezeigt werden soll","type":"integer","required":false},"page_for_posts":{"title":"","description":"Die ID der Seite, auf der die neuesten Beitr\u00e4ge angezeigt werden sollen","type":"integer","required":false},"default_ping_status":{"title":"","description":"Link-Benachrichtigungen von anderen Blogs (Pingbacks und Trackbacks) zu neuen Beitr\u00e4gen erlauben.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Kommentare bei neuen Beitr\u00e4gen erlauben","description":"Erlaube Besuchern, neue Beitr\u00e4ge zu kommentieren.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Website-Logo.","type":"integer","required":false},"site_icon":{"title":"Icon","description":"Website-Icon.","type":"integer","required":false},"elementor_one_welcome_screen_completed":{"title":"","description":"Elementor One Welcome Screen Completed","type":"boolean","required":false},"elementor_one_dismiss_connect_alert":{"title":"","description":"Elementor One Dismiss Connect Alert","type":"boolean","required":false},"elementor_one_editor_update_notification_dismissed":{"title":"","description":"Elementor One Dismiss Editor Update Notification","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Ergebnissatz auf Themes begrenzen, die einem oder mehreren Status zugewiesen sind.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Das Stylesheet des Themes. Dieses identifiziert das Theme eindeutig.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"status":{"description":"Beschr\u00e4nkt die Ergebnisse auf Plugins mit dem angegebenen Status.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Titelform im WordPress.org-Plugin-Verzeichnis.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID einer registrierten Seitenleiste","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Verschachtelte Widgets.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false},"form_data":{"description":"Serialisierte Widget-Formulardaten zur Kodierung in Instanzen-Einstellungen.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Die Seitenleiste, f\u00fcr die Widgets zur\u00fcckgegeben werden sollen.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":true},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":false},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Ob das Entfernen des Widgets erzwungen werden soll oder ob es in die inaktive Seitenleiste verschoben werden soll.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Ergebnissatz auf Bl\u00f6cke beschr\u00e4nken, die mit dem Suchbegriff \u00fcbereinstimmen.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","minLength":1,"required":false},"category":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Kategorie-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Stichwort-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"slug":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Vorlage (Titelform) \u00fcbereinstimmen.","type":"array","required":false},"offset":{"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer","required":false},"order":{"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Zu verarbeitende URL.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Ein alphanumerischer Identifikator f\u00fcr die Men\u00fc-Position.","type":"string","required":false},"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Eine eindeutige Kennung f\u00fcr die F\u00e4higkeitskategorie.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Input-Parameter f\u00fcr die Ausf\u00fchrung der F\u00e4higkeit.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Beschr\u00e4nkt die Ergebnisse auf F\u00e4higkeiten einer bestimmten F\u00e4higkeitskategorie.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]}},"site_logo":0,"site_icon":1556,"site_icon_url":"https:\/\/db0dol.fm-funknetz.de\/wp-content\/uploads\/2022\/04\/cropped-radiation-ga24efe698_1280.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/db0dol.fm-funknetz.de\/wp-json\/wp\/v2\/media\/1556"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
